Battery management system
Given the number of times, both here and on the Foxess facebook pages, folks ask "why isn't my battery charging" and get the answer of either "battery too cold" or "battery nearly full" is it possible to find out the BMS logic rules ?? It would then be possible to give accurate answers of, for example , "below 5C charge is limited to a maximum of 500W" or "at 90% battery charge is limited to 600W". Thus would be much more informative than vague "it's too cold/too full" type answer, but would require knowledge of the BMS logic control set. It would also allow folks to see if there is an actual problem if the charge rate is different to the logic set. Any thoughts anyone??
FoxESS H1&AC1(G2) 5kW Inverter
10 x TrinaSolar 450w panels
FoxESS EP6 5.76 kWh Battery
Re: Battery management system
Still valid today, along with a chart to see. https://www.youtube.com/watch?v=nDAw0KAYvcE
For charging, I see full rate at 21°C, with drop off in charge rates every 5°C, so 16°C and 11°C with EP11 on a KH7 inverter.
I don't recall seeing 6°C data, as my battery never got that cold, but I suspect there's a further rate drop at that bracket.
Google gave me the following for EP11 when I was trying to figure out what to set heater start temperature to.
15°C and above Full (27A)
11.0°C – 14.9°C ~10 A (charge) – 13.5 A (discharge)
6.0°C – 10.9°C ~5.5 A (charge) / 10 A (discharge)
Below 6.0°C ~2 A (charge)
The only validation I have for it is that I set it to 11C and I never see any throttling of my 2kW charge or 5kW discharge.
H1 5.0 E G2 inverter
EP11 battery
3680W solar 8 panels
daveg wrote: ↑Sun Nov 22, 2026 4:02 pm Google gave me the following for EP11 when I was trying to figure out what to set heater start temperature to.
{ snip }
Google is wrong or out of date with the results there.
You only get full rate charge with EP11 above 20.9°C, so starting at 21°C
Yes, your evidence demonstrates that.
I confess I'm always turned off by videos when I'm looking for a simple table - but if the simple table data is wrong that's a poor choice!
The question I wanted answered was what start temperature to adopt to ensure 2kW charge and 5kW discharge wouldn't be low temperature throttled.
So far 11C has worked ok for me, but perhaps I'll try an experiment of lower start temperature and a higher target charge rate to get an idea of real life throttling on my system.
Edit - I challenged Google Gemini that it's data was demonstrated on this forum to be wrong for the temperature at which unthrotted charging commences.
It fessed up and said that was for BMS up to 1.009!
It did then provide new data for BMS 1.011 onwards that aligns with your findings.
EP11 battery
@Entwood, you can see from a few replies here from me and Daveg that the information differs a fair bit (Google, and Will's video which is based on older firmware versions.) I suspect that the answers given to most forum posts/facebook groups are the 'low hanging fruit' So the answers are to the common issues, but really need following up with pointed questions to look at physical evidence (like the two pictures added)
@Daveg, I have seen some google searches that have pointed at posts I have made as 'gospel' I am not perfect, so who knows, it may have been me that poisoned the answers from earlier. And you also have seen that firmware revisions do play a part in it too, like you need v1.009 on EP's to get heater to work.
I know for a fact, at 8°C I can get full rate of discharge, my previous values discussed here for charge rates are backed by evidence, though I think the 6°C would be my absolute minimum to run the battery, as this seems to be the next logical bracket. So 6°C? I am unsure of, as never got that cold, but 11°C & 21°C seem to be the current brackets for latest firmwares.
Hi all, and thanks for the thoughts/responses :)
Seems most rely on either observed behaviour or google searches ... niether of which are "actual" BMS logic parameters, so I'm guessing no-one actually knows them.
Did give me the idea of using an AI search to see what I could find, and using my system info ... H1 5kW inverter, EP6 battery with BMS 1.013 then two AI engines gave - unusually - the same results !!
Max Charge rate
Temp >20°C SOC <80% = 4800w - 5000w (inverter limit)
Temp 15°C - 19°C SOC <80% = 2900w - 4200w (BMS limit)
Temp 10°C - 14°C SOC <80% = 1150w - 2900w (BMS limit)
Temp 0°C - 9°C Any SOC = 600w - 1300w (BMS limit)
Temp <0°C - Charging disabled
SOC 80%- 95% = 2500w - 3510w - (BMS Limit - Constant Voltage)
SOC >95% = 430w - 1300w 9BMS Cell balancing)
Do those numbers make any sense to you more experienced users than I ???
Issue being with Google searches or AI, they pull data from forums/internet, so the old saying of 'GiGo' applies (Garbage in, Garbage out)
The YouTube video and your search yields what I say are the old bands, to my own observations of the system in real use, shows the ranges I posted.
Given that Fox don't post firmware release notes (well update the notes) then posting BMS details has not been seen AFAIK. So that makes knowing the BMS and how it operates down to observations only, I have many charts of data stored here and there, but that applies to my system and depends on what firmware I had installed at the time of observation. To complicate matters further the BMS has a further mystery, if I have a perfect battery temperature, I can charge at ~7000W with my KH7 during the night, but during the daytime with PV available, it will charge at a max 7700W. If you read the manual for the battery, it seems to be above the so called charge limits, so go figure.
Short / best answer, is to observe your own system and see how it has operated in the past. Here is a post I made before, so you can pull real BMS data and then you'll know viewtopic.php?p=19593#p19593
