PV stops during force discharge
Hi All,
I have noticed over the last couple of days that when I force discharge my batteries, my PV completely stops. No solar being shown generated at all. As soon as the discharge stops, it returns. Is this normal behaviour? I would have expected it to continue and supplement what is coming from the batteries/provide the house load.
KH7
EQ4800 Master and 2 slaves
12 JA Solar 450w panels
Re: PV stops during force discharge
On the recent KH firmware, there is an option exposed now, along with the new App version to set PV during discharge events.
Do you know your firmware versions?
@MaterialBarracuda48 I also have this problem. I just updated my KH10 to the latest available firmware - now have:
- Master: 1.73
- Slave: 1.03
- Manager: 1.71
- Data logger: 1.12
I don't see any options for PV/Solar during discharge, and in a quick test ForceDischarge, solar still went to 0.
What version are you on? Where is the option?
@jj I have exactly the same firmware versions as you do.
When creating a discharge schedule, I see the options at the bottom if you scroll down, I am not sure that they actually work yet (the toggles) but not tested for a while either.
Ah I see, "Discharge from PV" is available while creating a schedule, not as a global setting. I personally use a VPP (Amber in Australia) who controls my inverter so I'll send them an email asking them to start using this option in their controls. Thank you!
Good luck with Amber, they have your inverter fully in their grasp.
