I have a new FOX ESS system of battery, inverter and EPS-BOX. I know that I often have a problem with the consumer unit RCD tripping after a power cut. It would be useful to simulate a power cut and recovery. I would also like to test that the system works correctly.
I was wondering if I could simulate a power cut using the EPS-BOX-SP?
When the EPS box switches automatically there is a loss of power for a couple of seconds; I guess part of that will be delay in detecting the loss, and part in time taken to switch. Now you can manually switch the EPS box by deploying an internal lever - maybe that would introduce enough of a switching glitch to do what you want?
(Disclaimer: I've not tried it)
Paul
Paul
