monitoring battery warming
Now that the temperature is dropping here in the UK I have enabled the battery warming on my EVO 10-5H. Please could someone tell me if it's possible to use Foxcloud to monitor when the warming pads are turning on/off?
There's a long list of battery analysis variables, but I've yet to find a comprehensive explanation of what they all mean.
Many thanks
Pete
Norfolk, UK
Re: monitoring battery warming
Fastest way to monitor, is the same way you turn it on, it should still discharge at full rate at 8°C, though you don't have same hardware as me (KH7 with EP11)
You should be able to see a heater animation hopefully like attached here viewtopic.php?p=10871#p10871 I don't have my heater on as it's in a garage with a blanket over it.
