Force Charge no longer working when EV charging
Hi All, noticed a change in behaviour this week, for years I've reliably had the SOC force charge over night when the grid import is cheapest (I'm with Octopus on IntellgentGo) , this week I noticed that when my EV is charging (typically at 23h30) then the FOX mode scheduler doesn't start charging the battery. Sat here now sucking up the grid all day unfortuntely.
Any tips, ideas?
Thanks in advance.
Paul
Inverter ; H1-5.0-E
Version_Master:1.70
Version_Slave:1.02
Version_ARM:1.78
Re: Force Charge no longer working when EV charging
Follow this post here, find your battery temperature please for the time period. viewtopic.php?p=19689#p19689
The last picture in the guide shows the type of details needed.
I think the firmware update could be a red herring, find the evidence from the inverter.
Just to add on to what @MB has said, as you have the gen1 H1 and there are no import limits for that inverter so the problem must be either in the mode scheduler settings, or the inverters manager has crashed stopping the schedule from running - you do have latest firmware so it is possible an upgrade has corrupted your scheduler settings.
Can you share a screen shot of your scheduler settings, I would suggest it is worth changing the work mode to 'self use' which will stop the scheduler running - then delete your schedule and re-add it, might also be worth just trying a small force charge schedule during the day when the EV isn't running to see that it will charge.
If you have home assistant, it's possible your Max charge current has been set to 0, so that's worth checking.
Failing that try a complete shut down and restart of the inverter.
Hi Dave, thanks for the prompt reply, please find here the ModeScheduler screen shot as well as an image taken yesterday showing the SOC force charge working fine (no EV plugged in)
To confirm, yesterday 18-11 when the EV was not plugged in over night to charge the SOC charged just A-OK I have included that chart as well.
It's surely not weather related, it's mild outside, was raining last night.
Hi MaterialBarracuda48, thanks for the reply and the link.
Here's the information, hoping I've selected the correct filter options relating to temps.
Hmmm not clear as to why that wouldn’t have charged as all looks correct. The battery cell temp is quite low but that should only result in slower charging - do you have any errors being displayed?, if you click on the app top right corner on the small ‘beacon’ icon, click the ‘history’ tab and see if there are any errors being displayed for the period where it didn’t charge.
I agree, those temperatures look fine... just it would charge a little slower as Dave has mentioned. Fox may have pushed out a firmware update to you and Rog999 that has either corrupted your scheduler, or a settings in the inverter for battery charge rates or other entities have been changed.
Next step would be the removal of schedule(s) and swapping to 'Self-use' work mode. You may have to login to the older v1 website to nuke the schedule potentially too.
Then a full power down/reboot of the system, checking the battery is registered etc (SoC reading ok) then program in a test charge or set normal charge time and check next day.
Hi, i've been onto Fox and reproduced the behaviour today, a mode scheduler set to Force Charge worked when the EV wasn't charging. Change the schedule, force charge the car, waited for the batt schedule to tick over and the battery didn't charge. Fox confirmed they saw similar, engineer assigned.. to be continued...
Paul, you may want to check the settings here, see if the import limit has been dropped. viewtopic.php?p=19701#p19701
You can verify the value on your FoxCloud2.0 App -> Quick Settings and you should see import limit greyed out.
Seems Rog999 had noticed a lower import setting since FW upgrade in his thread.
Hi MaterialBarracuda48, thanks for your reply, FOX confirmed I don't have that feature given the version of my inverter, they suspect it's CT clamp related but I've had no changes that I'm aware of and this behaviour only just started happening this week. Going to call the local electrical company out who installed the Hypervolt, they do commercial solar. Don't want to bother my installer who are up actually up in the midlands quite some way from me , even though they sold thru a local salesperson they're too remote. Will keep the thread updated with what I find.
Check this tree diagram here https://www.manuals.co.uk/fox-ess/h1-50-e/manual?p=32
Menu -> Setting -> On Grid -> Power Limit
Menu -> Setting -> Battery -> Max Charge Current
See if you can locate these on your panel, hopefully they exist (if I have correct manual)
Hi, the FOX engineer saw this negative number on the inverter when the EV is charging and said this is a symptom of the CT clamp being an issue, thanks for the manual , I'll check when I can and come back.
Just looked at your picture a little closer for your charge in your 2nd post. Your SoC went to 100% and then drops down to ~15% I guess as your minimum. What's odd, is your system shows little to no load to cause the drain.
Well maybe clamp is on wrong wire / reversed / broken or fell off, hopefully you can get to the bottom of it quickly.
Anyhow, hopefully it can get sorted soon.
here's the settings values you mentioned..
If the above linked manual is correct, you could bump current to 40A or 45.5A potentially if you wish. Have a sniff around in the various sub menus, you'll get yourself a good familiarisation with things overall.
It's good you are taking pictures too, as you have reference material for future if settings change.
MaterialBarracuda48 wrote: ↑Fri Nov 20, 2026 8:46 am If the above linked manual is correct, you could bump current to 40A or 45.5A potentially if you wish. Have a sniff around in the various sub menus, you'll get yourself a good familiarisation with things overall.
Sadly the Gen 1 H1 has max battery current of 35A so that's set as high as it will go.
Really interested to hear what's caused this, now that Fox don't update gen 1 every few days as they do on the later generations, it's usually so reliable ;)
Dave Foster wrote: ↑Fri Nov 20, 2026 9:41 am Sadly the Gen 1 H1 has max battery current of 35A so that's set as high as it will go.
Thanks Dave, my in depth product knowledge is mostly limited to my KH7 :D
I have popcorn ready for this thread, be interesting to know how it pans out.
