Morning all
Since updating my Fox ESS H1 G2 5kw inverter yesterday, something strange is happening when I am attempting to use the force charge schedule within the mode scheduler.
I am on octopus intelligent go with an ohme charger. The charger specified that it was going to charge today at 7.15-7.30am, so at around 7.10, I added a force charge window in to my fox app mode scheduler to charge the battery for that 30 minute window. But it didn't work properly (always used too before the firmware update). The graph attached shows what happened. (It should be a flat line for the 20 minutes it had remaining in that 30 min window, and should have been lower on the y axis too).
The overnight force charge window worked fine, as can be seen in the graph.
Has anyone else experienced this?
for comparison, this is how it used to perform 2 days ago
Check your Import power hasn't been adjusted since the firmware change.
Next, check the battery temperature wasn't extremely cold at the time of charge.
If you don't know how to check values, post back.
Thanks for quick reply. Import power was not changed. Battery housed inside garage - not any colder than 2 days ago.
Worth pointing out (and think you can see this), that it actually also discharged at 7.21am
as an update, I tried it again tonight - car charging at 6kwh, house was using about 2kwh, and battery charged at around 2kwh too (although set at 5kwh). It looks as if, since the firmware update, that my whole house import limit is now at 10kwh! Indeed, when I look at the graph in the app, the max y axis is now 10kw.
Start looking at some graphs viewtopic.php?p=19593#p19593
My own charging findings for my EP11 on KH7 inverter
21°C = 7.0kW (Full rate charge)
16°C = ~5.0kW
11°C = ~2.5kW
6°C = Sorry, never got that low, but guessing this is another 'bracket' as seems there's 5°C between the charge levels.
At 8°C I can discharge at full 7kW, discharge does not equal charge rate thankfully.
16°C = ~5.0kW
11°C = ~2.5kW
Hi Rog
Out of interest what are your inverter software versions?
I've noticed a change in behaviour (after many years of reliable force charge overnight) recently but wasn't aware of any inventer software upgrade myself, these are my versions:
Mode: H1-5.0-E
Version_Master:1.70
Version_Slave:1.02
Version_ARM:1.78
The change I've noticed is that when my EV is plugged into charge the FOX SOC doesn't charge at all, three times this week (and it's only started happening this week) I've woken to find the battery at the minimum level and they all conincided with my car being plugged into charge overnight on Octopus Intelligent GO.
My mode schedular hasn't changed.
I'm pretty new to to this forum, should I post a new topic rather than a reply here to this specific issue?
Cheers,
Paul
Mode: H1-5.0-E
Version_Master:1.70
Version_Slave:1.02
Version_ARM:1.78
Cheers,
Paul
Again, thanks for the reply.
One thing I hadn't mentioned before, but will now since ChatGPT has highlighted it - I also have an EPS Box.
ChatGPT wonders whether the firmware update has changed the inverter's grid bypass behaviour.
What I can also add is this - the car schedule was 7-7.30am again this morning. I forced charged the battery during this time. Battery charged at around 2kw (whole house load was about 9kw [2 battery, 6 car, 1 house])...but we unplugged the car earlier than 7.30, and for the remaining tinme, the battery then charged at over 4kw.
Paul, my versions are as follows :
Master : 1.59
Slave : 1.04
Manager : 1.45
inverter model = H1-5.0-E-G2-WL
Master : 1.59
Slave : 1.04
Manager : 1.45
@MaterialBarracuda48 - I found this other post that you responded to : viewtopic.php?p=19560&hilit=load+limit#
This made me look at my setting of Import Limit under the Quick Settings, and I can see that it is set to 9.2kw ! So this probably explains it. I cannot change it. I presume it was set during the recent firmware update. I will ask my installers to change it and advise
But I'm surprised that no-one else has reported this in the channels?
You should be able to DIY on your inverter controls normally.
Video shows you how to adjust export limit, but import limit is seen here in this same sub-menu.
