Dear Fox ESS Technical Support,
I am having a Fox ESS H1 hybrid inverter installed as part of a solar PV and battery storage system. I wish to connect the H1 to a Vaillant aroTHERM Plus 7kW heat pump (controller: sensoCOMFORT VRC 720f/3) using the SG-ready protocol, and I would be grateful for clarification on the following points.
1. Does the H1 have a built-in dry-contact relay output for SG-ready signalling? If so, which terminals are used and what are the contact ratings?
2. If no built-in output is available, what Fox ESS accessory or external relay module is recommended, and how does it interface with the H1?
3. How is the SG-ready output configured — via the Fox ESS app, local inverter display, or firmware parameter — and what conditions (surplus generation level, battery SoC) trigger State 2 (encouraged) and State 3 (commanded) signals?
4. What signal cable specification (voltage, core count, cable type) is appropriate for the two-wire run between the H1 and the heat pump SG-ready input terminals?
5. Is there any known compatibility issue between the Fox ESS SG-ready output and the Vaillant VRC 720f/3 SG-ready input?
Any relevant wiring diagrams, application notes, or commissioning documentation would be appreciated.
Hi, hope you're well. Did you find the answer to these? I also have a H1 inverter and have just had a Samsung ASHP installed so would be interested in learning about this. Thanks.
On the H1(G2) there are two dry contact outputs, on the "meter/ct/rs485" connector pins 10 & 11 and 12 & 13. Both are configurable for SG-ready1 or SG-ready2 through the installer advanced settings "DryConfigure" and "SgReadyConfigure", note 10 & 11 is by default set for switching an external EPS contractor. Unsure of the contact ratings as no info in the manual, would guess about 240v/100mA max.
Your other questions I am unable to answer as I've not used this function. Some details are given in the H3Smart inverter manual
Manager(ARM):1.79
Master:1.59
BMS:1.013
Manager(ARM):1.79
Master:1.59
BMS:1.013
