I cannot understand why my inverter has a wifi access point. Worse, it's on channel 9, which interferes with two of my proper access points, on channels 6 and 11.
Who or what accesses this AP? Surely nothing internal to the panels/batteries/inverter system?
So how can I disable the AP?
The AP can't be disabled on the WL series, it remains in STA mode so that you can re-connect to it when it loses connection or the router ssid is changed (which for many people is a yearly affair) - why it can't be disabled, or enabled with a button press I can't answer that's one for Fox. You can install a LAN datalogger and remove the aerial to stop the interference but it's a poor solution.
