Time zones on App
This may be a daft question but I use the work scheduler to control self-use and forced charge periods. Is this controlled by the app on the phone or are settings stored in the cloud? Reason I as is I am going abroad and if it is controlled by the app on my phone the the time difference will mean I am not charging my batteries within the 11:30 - 17:30 GMT cheap period from Octopus. Does that make sense to anyone?
Re: Time zones on App
The Inverter, as part of the initial install phase, will have it's region set, it will sync time to the time zone it is installed to. You being abroad, and changing settings for charging, should be pushed to the Inverter clock just fine.
If you are on a fixed time for cheap power, then you shouldn't need to adjust times. Note that you can also view graphs and data to check that it is in fact obeying the times programmed.
