Hello everyone,
I have a Fox ESS H1-6.0-E-G2-WL hybrid inverter connected to the grid through an inverter-type voltage stabilizer.
I am constantly experiencing problems with battery charging. In some cases, the battery does not charge at all, while in others, the charging power is extremely low.
On a few occasions, the battery did start charging at a relatively high power, but this seems to be an exception rather than normal operation.
We also tried switching the voltage stabilizer to bypass (transit) mode. In this mode, battery charging started, but the charging power fluctuated significantly due to unstable voltage at the stabilizer's input.
When the inverter is connected directly to the grid, without the voltage stabilizer, battery charging works normally.
Has anyone experienced similar issues with this inverter when using an inverter-type voltage stabilizer?
Could this be related to the quality of the AC input waveform, grid parameters, or the inverter's grid code settings?
I would appreciate any suggestions or recommendations on how to resolve this issue.
Thank you in advance!
I've never come across that before, but the first thing to check is are there any errors being reported - in the app, click the alarm beacon in the top right corner, then history and select a date range if necessary. If there were voltage or frequency errors you should be seeing them here.
Regarding error codes, the only errors we encounter are related to the AC grid input:
- Error code -1
- Error code 26
- Error code 27
We also experience frequent power outages in our area.
Currently, the battery state of charge is 84%, but the inverter is not charging the battery at all, despite the grid being available.
The charging issue is particularly concerning because we need the battery to remain charged and ready to provide backup power during frequent grid outages.
- Error code -1
- Error code 26
- Error code 27
