I am new here and new to solar. System installed on 9th. September
Last night battery ceased discharging at 22.00 and commenced a forced charge at 1.8kw for an hour. The SOC at 22.00 was 29% when this commenced and system SOC is 15%
when the charging stopped the battery was at 45% but was not discharging.
My Mode Schedule has a Forced Charge between 2 am and 5 - as am on Octopus Flux tariff. This did not happen
Battery is slowly self discharging, but no discharging to the house load.
Battery temperature is now -0.7 and was + 4.4 when this happened.
Should I re boot the system, or try a forced Charge to warm up the battery?
I am at a loss to know what to do as help line from installers not available at weekend
Your battery was doing emergency charging to keep the cells warm, two recent threads here to read.
viewtopic.php?p=19548#p19548
viewtopic.php?p=19568#p19568
You will want to insulate the battery from the extreme cold, it will begin to affect the charge/discharge rates of the battery. For example: viewtopic.php?p=12714#p12714
