Mode scheduler (how to charge within specific time)
Hi everyone,
I have a Fox ESS P3-Pro-20.0 with approximately 28 kWh of battery storage and no solar panels.
My GRID input receives power from either the city network or a shared generator. Generator electricity is expensive, so I want to:
- City power available: Charge batteries to 100%.
- Generator running: Stop grid charging and power the house from batteries until minimum SOC.
The problem is that Self Use/Back up/Mode Scheduler continues charging batteries from GRID, even outside Forced Charge schedules.
I tried adjusting System Min/Max SOC (10–30%) while the battery was at 78%, but it simply remained at 78%, neither charging nor discharging.
Batteries show 18 degrees.
Is there a way to manually enable/disable grid charging in FoxCloud 2.0 without/with using time-based schedules, while still allowing battery discharge in Self Use? I tried disabling GRID in settings, but it behaves similarly to adjusting Min/Max SOC, i.e. leaves the battery at particular charge.
Thanks!
Re: Mode scheduler (how to charge within specific time)
m1 wrote: ↑Fri Nov 13, 2026 7:32 pm My GRID input receives power from either the city network or a shared generator. Generator electricity is expensive, so I want to:
The Inverter (scheduler & settings) won't know what power is what (Grid or Generator)
Simple question, is the time of the events static, or does the starting of the generator occur at random?
If random, there's nothing you can do, apart from adjust settings in app on the fly to turn off charging and go to 'Self-use' work mode.
MaterialBarracuda48 wrote: ↑Sat Nov 14, 2026 10:18 am
Correct, the Inverter (scheduler & settings) doesn't know what power is what.
So I do have a schedule released same day when the power goes off. So the time of the events is static. Say city power available at 08:00 - 12:00. Outside this time frame, generator turns on. The question is: How do I make the batteries charge specifically within this time frame and not in any other? Self-use mode still turns on Forced Charge whenever.
I tried: (1) Regulating max SOC, (2) Disabling Charge from GRID in Mode Scheduler Force Charge setting, (3) Setting Force Discharge along with Force Charge periods. But they all work weirdly i.e. still charging.
Currently AFAIK some of the toggles in the app/settings don't work correctly.
If the grid power time is static, or you know the times in advance, then you only need to set a timed charge to fill the batteries as much as possible, and outside of this window, just have it in 'Self-use' mode.
Just set your 'Global' MinSoc/MaxSoc at 10% and 100%
Can you show a picture for your settings? Do you have a picture of how you are setting up charging schedule?
MaterialBarracuda48 wrote: ↑Sat Nov 14, 2026 12:09 pm Currently AFAIK some of the toggles in the app/settings don't work correctly.
Here is the screenshot of my settings. Really appreciate your help.
https://ibb.co/Xf503Y3F
The issue here is that outside the schedule, it keeps charging in Self-Use mode.
Your import power is set to 1kW, so would take more than 28hrs to charge it up, is there are reason why this value is low?
If not, then up that value to as high as you can set it, 10000 or 20000 Watts.
MaterialBarracuda48 wrote: ↑Mon Nov 16, 2026 9:24 am Your import power is set to 1kW, so would take more than 28hrs to charge it up, is there are reason why this value is low?
No reason. Just experimenting.
So if I understood correctly, taking into account my problem and the screenshot, the expected behaviour is the following:
1 - Batteries charge within the set time period.
2 - Outside the time period, Self Use turns on, and batteries discharge until 10%.
Please confirm if possible.
This is the behaviour on Self Use and using mode scheduler. Constantly charging to keep 100%. https://ibb.co/bjf71k4T
Can we conclude that it might be a problem on Fox’s side and I need to wait for an update?
One last picture may be needed, under 'Quick Settings' what is your battery control values for 'System SOC Range'
Mine are Min: 10% Max: 100% with Off-grid Min. SOC: 10% The last one if set to 100% can make it so the battery tries to keep charging to 100% and not discharge.
Beware also, in your post you did mention the usage of 'Backup' work mode, this will also force the charge from grid.
Which was why I asked to see your schedule.
So can you also post your final programmed settings for your work mode?
MaterialBarracuda48 wrote: ↑Mon Nov 16, 2026 10:04 am One last picture may be needed, under 'Quick Settings' what is your battery control values for 'System SOC Range'
Here is the picture. Mine is the same as yours.
https://ibb.co/DP2x3PKt
Backup and Self Use modes work the same way for me.
There is then a chance that your inverter has 'crashed' then, so it may need a restart, or Fox to push a new firmware then.
MaterialBarracuda48 wrote: ↑Mon Nov 16, 2026 12:21 pm There is then a chance that your inverter has 'crashed' then, so it may need a restart, or Fox to push a new firmware then.
Got it. Thank you for the help
