My installer said that my two E11 batteries have internal heating which is important as they are in the garage. However the model number does not have an H that I believe indicates that it has heating capabilities.
The serial numbers are:-
60EP11104ABP039
60EP11104ABP041
Is there any way to determine whether they have a heating facility or not?
I have opened a ticket with Fox but they failed to respond even after I opened another ticket as a reminder to the first!
Any help on this much appreciated
EP11 batteries with serial nos. starting 60EP1 have the heating function, see https://fox-ess.tech/how-to-determine-i ... -function/
Manager(ARM):1.79
Master:1.59
BMS:1.013
Manager(ARM):1.79
Master:1.59
BMS:1.013
You have heater models. You might need your battery and inverter firmware to be updated before the option will appear under the quick settings on the plant flow overview page.
Thank you both for your prompt replies, I can now snuggle down beside them if everything goes pear shaped.
Hey
Your garage will offer a bit of cold protection, my battery is outside hung on the wall of my house. So glad it has a heater.
My Inverter has no option for heating, do they need to be?
No they work fine at low temperature, any work they do will generate some heat and they are always working either from solar or battery - but they are good down to -25Coxfordmark wrote: ↑Thu Sep 25, 2025 9:37 am My Inverter has no option for heating, do they need to be?
Hi, new to this. Am going to assume that my battery doesn't have heating, it was cold last night and the overnight, off peak charging was at a reduced rate. My question is, does anyone know of a retro fit option? Or a suitable heater blanket option? I have looked around and it doesn't look like there is anything specific that is manufactured?
Depends on which battery you have, normally they are marked with an ‘H’ or ‘Warm’, and it’s confined to the later EP, EQ and CQ models - if your app gives you ‘battery warmup’ options in quick settings they do have it.Mark Newstead wrote: ↑Fri Nov 13, 2026 8:05 am Hi, new to this. Am going to assume that my battery doesn't have heating, it was cold last night and the overnight, off peak charging was at a reduced rate. My question is, does anyone know of a retro fit option? Or a suitable heater blanket option? I have looked around and it doesn't look like there is anything specific that is manufactured?
Most people with older batteries have built simple enclosures using 50mm kingspan/recticell sheets to form a box around the battery and held together with duct tape - that’s normally all it takes, there are quite a few older posts here with some images - one here https://foxesscommunity.com/viewtopic. ... ion#p19022
Hi thanks for the reply!
Yeah I just googled and my battery is not of the type with heating, so looks like I am going to have to come up with a DIY option, as you suggest!
