P100-6H device question
Just have my P100-6H Hybrid system for a month.
I have something cannot understand and hope u guy can help. I'm in Vietnam so the supplier seem not to understand well their device :))
1. Min Soc problem?
My device is 95% DoD so I want to use all of them. At first I set Min Soc 5%, Max Soc 100%, Offgird Min Soc 5%.
Recently. The Min Soc automatically change to 10%.
I tried to set it back to 5%, the app allow me to (Picture), but about 1 hr later, it automatically back to 10% again.
Is it normal or some error? I notice it since the last firmware updated (not really know does it counted for?).
2. The system draw some 10-30W some time, just 1-10sec, and sum for 0.5kwh per day, it's normal right? And how can I minimalize this?
Thank so much for your help.
Re: P100-6H device question
My first ever attempt at a reply so someone feel free to correct me if I'm wrong.
1. In the UK min soc is frozen at 10%. We cannot set a value below this for battery protection. I can't even enter a value below 10% never mind save one that gets overwritten later. I don't know if Vietnam is the same and what you are seeing is some quirk of your app version or whether you're genuinely allowed to go to 5% (I know Australia can go to 0%) but if you are permitted to drop to 5% it may be you have an old app version or possibly even one that is not intended for your country (if that is possible).
2. Quick durations of grid draw are normal caused by the system not being able to adjust to changing house load as quickly as the grid can. Across a whole day this only amounts to 100-200w so is negligible. Within the app there is a setting to help compensate for this.
From the home screen go to quick settings then meter compensation. Play about with some -ve values. My understanding of this is that it tries to set a bias of whatever your setting is to always feed the grid meaning you should see less of those quick imports. Be careful though because if you set it too high, you may fix your issue but discharge far more back to the grid than you want to thus depleting your battery quicker.
@Spiral, a good reply.
1. Australia as mentioned by Spiral, has 100% allowed DoD range, but the software/firmware seems to be stuck hard on only allowing 90% DoD. I think you are best to give up on setting the MinSoC to below 10% (try again every 3 months by all means)
2. Spiral also is correct, there is the 'Meter Compensation' you can see in your picture. If you take your 0.5 kWh of daily grid use, and multiply by 1,000 to get Watts per 24 hrs, you get 500 Wh use per day. Now divide 500 by 24 hrs, and you get 21 W. If you set a - 21 W (negative) value, then you are 'pushing' back energy towards the grid. Also correct is to set the value, and wait to get the results from a few days, or a week to see, then make small adjustments as needed.
I have a -16 W value in mine, and import just the tiniest amount... I could adjust this to -17 / -18 W to get a full 0 W import, but I am fine with this.
Really helpful for my knowledge. Thank you two so much
