I just ordered a FoxESS S3000-G2 inverter and a WaveShare Industrial Grade Serial Server RS232/485 to WiFi/Ethernet Modbus MQTT Gateway in order to integrate this inverter with Home Assistant.
Apparently I made a misguided decision, as it turns out that the Home Assistant modbus integration doesn't really support the S-Series inverters - see:
https://github.com/nathanmarlor/foxess_modbus
Please advise if there are any other modbus integration projects I should try.
The location I'm planning to use this inverter is remote and I do only have partial cellular (4G) connectivity, therefore a cloud integration is useless. I only need to check and read the AC output power of the inverter in order to start/stop appliances (heating/air conditioning & co) that are already integrated in Home Assistant.
Thanks in advance for any help/advice.
The original S series did not support modbus and there was a clunky hardware hack that allowed you to hijack the RS485 polling message that wen to the datalogger, but have a read of this thread as something may have changed on the G2 viewtopic.php?t=3477
Alternatively you can use the cloud interface https://github.com/macxq/foxess-ha which gives you 5 minute data samples, and if you need real time load or grid usage you could use a shelly EM with ct clamp to give you that - anyway best of luck, if you could confirm what you eventually implement it'll be useful for the community.
Thank you for the quick reply and pointing me to that thread. I wasn't aware that someone already put some effort to make the modbus communication work. I'll catch up with that user and hope that his findings will migrate into the HA integrations. Still confused why FoxESS itself doesn't invest effort into this. It's number 1 in residential setups worldwide and Home Assistant is number 1 in residential automations worldwide, should just work together in the best interests of both parties.
Since the cloud control is no option for me, I'll consider maybe an external independent WiFi smart meter on the inverter AC output that I could read from HA and base my decisions on these power output readings. A pity I'll have a smart inverter mounted on the wall that will actually act as a dumb one. A waste...
