H3-8.0 Smart zusammen mit Q1-2000-E
Hallo,
Ich habe folgende Anlage:
H3-8.0-Smart mit 7,44 kWp, Smartmeter DTSU666
Q1-2000-E mit 4,55 kWp, Smartmeter DDSU666
Speicher EQ 5000
Beide Anlagen sollen zusammen in der Foxcloud angezeigt werden und die gesamte Leistung soll auch zum Laden des Speichers genutzt werden.
Wie müssen die beiden smartmeter verbunden/konfiguriert werden?
Gruß Buchi1965
Mit freundlichen Grüßen
Buchi1965
Re: H3-8.0 Smart zusammen mit Q1-2000-E
The Q1-2000-E and the H3 are separate inverter systems, so you can't just add the second meter to the first system's CT input. In the Foxcloud, both plants normally need to be registered under the same account so the portal can aggregate them, but true combined charging control comes from the meter role: one system must be set as the master/grid reference and the other should not fight it with its own export logic. Check your firmware and the meter address/baud settings match before assuming it will behave as one system, since cross-system storage sharing isn't guaranteed.
The point about the two inverters being separate systems is worth emphasizing, since the Q1-2000-E won't simply merge into the H3's CT input. Registering both plants under one Foxcloud account may give you a combined view, but that is display aggregation, not shared charging logic. For the storage to draw from both arrays, the meter roles have to be coordinated so only one unit acts as the grid reference, otherwise the export control of each system can work against the other. Matching firmware and confirming address and baud settings on both smartmeters is a sensible first check before expecting combined charging to work reliably.
