Hi, while looking to get a FOX ASHP installed, as it keeps it all simple and managed via the 1 app, my installer sent me this as we are looking to install a FOX ASHP to replace the heating oil boiler we currently have.
"Hi, I know Fox ESS make heat pumps but they are not listed on the MCS website so I won’t be able to get you the government grant for it. I can do you a quote for either a Grant heat pump or Viessmann heat pump but it won’t integrate with your solar set up the way you want it to"
I'd ideally like to keep it all FOX but is there any news on if the FOX UK ASHP will be added to the MCS website to get the grant?
If not then I'm likely to get a smaller ASHP for downstairs only and a split system aircon multi room system for upstairs. This will give aircon in summer and heating in winter with each room having its own header and controller. I'll then be able to remove all the rads and pipework upstairs as the house currently has all floors upstairs lifted due to a full house re-wire.
48 Panels in total setup (6 x 8 panel strings)
34 x 440W - Jinko Tiger Neo 440W N-Type All Black Mono Panels
14 x AIKO NEOSTAR 2S 465W ALL BLACK N-TYPE MONO PANELS
Fox ESS EC2900 - 20.16kW Li-ion Battery (1 x Master + 6 Slaves @2.88kWh each)
3-Phase Export
3-Phase Export
As your guy said if you are applying for the ASHP grant you will be refused at least for now with the FoxESS ASHP which from talking to my installer is not even available yet in the uk! I went for the Grant 290 9k for my house. They have a good reputation and don’t seem as bulky as others.
22 465w Solar Panels
FoxESS KH8 Inverter
FoxESS 3 off EP12 Batteries
Hypervolt Home 3 Charger
Grant Aerona 290 9KW ASHP
OVO 20p SEG
FoxESS KH8 Inverter
OVO 20p SEG
