Do people here who use Tigo optimisers also have the TAP & CCA installed to monitor individual panel performance?
Google tells me that Tigo increase your optimiser warranty from 5 to 25 years IF you install the CCA & TAP - but maybe that's a regional thing and not applicable to the UK market.
I have a Fox H1-G2 inverter, which I understand does NOT have an integrated Tigo data logger, so I would need to get the CCA.
I have Tigo optimisers but no TAP/CCA, for my application its quite simple some panels are part shaded at certain points of the day which standard Tigo’s handle perfectly well. If you have a complex application or want to know exactly how each of your panels are performing over time you’ll need the TAP/CCA combo. You do get the extra warranty but as solid state devices they typically follow the bath tub curve and if they’re going to fail it’s on install or at the end of a long life.
If an optimiser fails, does the whole string go down? I guess it might depend upon what the failure mode is.
I've just gone and ordered a TAP & CCA set. Not for the extra warranty, but just for fun!
Yes, most likely is it would render the panel unusable, but it's always possible it could take out the string, but to be fair that could also happen with TAP/CCA the main difference being you would know why !
I'm sure having it will give you another toy to keep you busy
Another toy, indeed.
After reading the details of the commissioning of this CCA & TAP system, I'm not sure I will be installing it.
When the system scans your devices, it switches them from a "blind" optimiser into one that needs a continuous "keep-alive" signal from the TAP. Obviously, the intended function for this is for rapid shutdown of the solar panels - turn off the CCA & TAP and each TS4 turns of the respective panel.
But what happens if the commissioning fails to detect all TS4 optimisers - for whatever reason, wrong serial number (I don't have the barcodes, just a written sheet), or radio interference.
What I wanted was just a means to see individual panel performance.
Sorry to say i'm no expert with this, but as I was led to believe it, unless you have strict regional regulations (USA is one such region) where a loss of comms will force a rapid shutdown (RSD) by design.
If you don't require RSD then the system will continue to function as if it were operating in blind mode upon loss of the TAP.
TIGO support are very good, i'm sure they've been asked this before - ping them a message (make sure you let thek know which country you are in) and see what they say.
Ah, OK. I was going on what Google AI said - but they're (she/he?) very often talking out of their a*** !
I'm in the UK, and will contact Tigo to see if they can clarify.
