Cold weather stopping forced charge from grid
Hey all, wondering if anyone around Australia is having the same issue as myself in Melbourne with my FoxESS batteries and inverter outside on a south-facing back wall.
Earlier this week the temperature dropped down to about 6-7C and the battery temp got so low that the "frost" indicator was shown in the android foxcloud v2 app. I didn't think too much of it until 11am rolled around and the batteries were only charging at 3.7kW, which for the three hours with Globird is not enough to fully charge my ~42kW.
Now, it would have been really nice for the sales people or installers to mention this heavy down-side to outdoor battery placement, as I likely would have installed in my garage instead, at least I could have considered the options and done some research on how often this limiting factor might occur in Melbourne, etc., etc.
So now I'm looking to perhaps build a cover with insulating material, polystyrene with aluminium sheeting or something similar, and possibly use a heater pad and controllable switch to turn on the pad when the temperature drops too low, etc. I have a Homey Pro home automation system set up for my house and I have built an app/device to pull the FoxESS data from the cloud, so I can see the internal BMS-reported temperature.
By the looks of things online forums, etc., this API-reported temperature is NOT the same as the lowest batt. temp value which no doubt actually drives the BMS to slow charge/discharge to prevent damage, but I figure I can probably calibrate one to the other over time, i.e., if the BMS API temp says 12C, then the lowest temp is likely to be 6-8C or something like that. Either way, turn on the heater pad until we see the BMS report 20C or whatever, then switch it off.
Chances are I'd only have this flimsy enclosure installed over the battery during winter, or I could potentially add a fan to the top of it and drive that when too hot, sucking cooler air from the bottom...future improvement maybe.
Anyhow, the questions are:
1. Has anyone built something similar and can offer advice on materials, etc.?
2. Does anyone have any particular knowledge on the relationship between the BMS temp via API and the actual lowest one likely used to drive BMS throtting? Or perhaps other method to get a close approximation, e.g., physical temp sensor attached to the bottom-most battery?
NB:
- I see that it appears the lowest batt temp is probably exposed via MODBUS, but I'm not in that space...yet.
- I see that there's plenty of UK users who install covers / insulation to their units, usually in the loft, but I guess I'm looking for something more Aus-based, at least as far a materials are concerned.
- No, my unit doesn't have a warming function in the BMS; again, if I had of known about this fairly heavy drawback, I'd have probably asked for that model / upgrade.
Any help or comments would be most appreciated, cheers.
Re: Cold weather stopping forced charge from grid
Ok, not a lot of feedback / comments on this one...maybe it's only me that is having this issue...dunno. I'm tempted to delete the post out-right, but I guess I'll leave it in case someone notes the same / out of interest, not a big deal.
As a side note, I don't think I'll spend any money on construction of said enclosure as it's likely false economy; it 'cost' me about $1.50 in lost credit on the Globird ZeroHero plan from not feeding to grid 6-8pm that day - and any others that might occur later, so...who cares, really.
Hi. If any of this helps for my setup in the UK. I have batteries in the garage but still were throttled for charge and discharge when below 10 degrees c. So built square cover from Kingspan 50 mm insulation which has a thin aluminium cover. Don’t forget to leave recommended 300 mm all round. I then use Home Assistant to turn on a small greenhouse type heater that is about 90w per hour, below 11 and off above 14. I also have an automation that warns me to remove cover if high temp goes above 30 and to fit below 14. The smart plugs are Zigbee and very simple to pair in Home Assistant. My inverter is connected using Modbus so no experience of api.
John
In pictures from another user here
viewtopic.php?p=12714#p12714
An old video from Will, with a chart of Temperature vs. charge rates (chart around 5.5mins in roughly)
A post of mine of charge Amps at the various Temperature points
viewtopic.php?p=16070&hilit=charge+rate#p16070
Thanks John and MB48, both useful posts with good data, etc. Much appreciated.
CrazyGrayV8 wrote: Fri May 15, 2026 8:41 am As a side note, I don't think I'll spend any money on construction of said enclosure as it's likely false economy; it 'cost' me about $1.50 in lost credit on the Globird ZeroHero plan from not feeding to grid 6-8pm that day - and any others that might occur later, so...who cares, really.
It might be an idea this year to just let it go and see what you make in total for the Winter season.
Then you can compare the money you make from exporting in Winter/Summer and work out you 'loss' to see if fitting insulation would be worth spending on.
If you 'lost' $50 a season, but would have to spend $500 on materials, then probably not worth it for a 10 year payback.
Yeah MB48, that's a good plan. I think I'll do exactly that, see how it goes for a year.
Who knows, with global warming kicking in, I'll probably get more concerned about it being too hot in summer, and winter will be fine! :lol:
Sad but true :!:
Yes, I noticed same problem in Canberra when cold recently. Also agree would have been good to hear about that possible issue when considering install locations.
I'm hoping to charge battery at night off-peak, and possibly middle of day (if I can get a plan with free hours), as my solar generation is really bad in winter. Hopefully this isn't going to foil my plans...
low temperature warning screenshot
Hey mate, I have this issue too
My friend installed his battery in the garage and would charge so much faster then mine.
My battery is installed East side of the house and the cold temp icon shows with my slow charging.
I've since got an EV and made it full speed charge at 10am to warm up the batteries and since kind of Eliminated this problem. EV charges at 9-10am to warm up house battery to get ready for the Globird free charge at 11am-2pm.
My problem is now I am unhappy with the intergration and app for Foxess EV chargers, they need to fix it.
vince088 wrote: Mon Aug 31, 2026 12:15 pm My battery is installed East side of the house and the cold temp icon shows with my slow charging.
Which city are you in?
I also got EV and more solar panels. So ended up tending to charge cars during night, and/or charge the battery during night. Didn't really notice the problem anymore, maybe because of more continuous use. Also got firmware upgrades, maybe they did something, not sure.
Melb
