Mode Scheduler from a browser
I cannot find the Mode Scheduler from the dashboard in a browser (Firefox and Chrome). I have looked under quick settings and work mode only shows the 4 basic modes. The User Guide shows it being accessed via the Devices section but it is not visible to me:
I can see the Mode Scheduler in the Fox app but haven't actually confirmed that it works.
Can someone point me in the right direction please?
TIA
Re: Mode Scheduler from a browser
On the right hand side of the dashboard, click on work mode ‘Details’, then drop down the box, it’s under mode scheduler
Thanks, found it after clicking advanced.
As of the last few days I cannot open the scheduler from a Win 11 PC....the roundel just spins and spins, have tried 3 browsers and 2 laptop/PC's
FOX KH7 7kw hybrid inverter
EN-EPS-BOX-SP gateway
davidwf15 wrote: ↑Thu Aug 20, 2026 12:22 am As of the last few days I cannott open the scheduler from a Win 11 PC....the roundel just spins and spins, have tried 3 browsers and 2 laptop/PC's
If it doesn’t work in the app as well it could be a data connection issue, when you click the scheduler button it fetches in real time the schedule from the inverter which will need a good internet connection - probably worth starting with the easiest things and restart your router, if it still isn’t working next step would be a shutdown restart of the inverter.
nope, the app is immediate
I have figured out the issue and started a new thread viewtopic.php?t=3593
https://www.foxesscloud.com/v2 redirects to a non https login route, and then to a non https dashboard. This dashboard is where the work mode popout fails, because it tries to access Crypto.randomUUID() which does not exist.
https://www.foxesscloud.com/v2/ and https://www.foxesscloud.com/v2/login both stay on https.
Aside from this bug in the routing, I am not sure why a non https login is even provided. There should never be a case where login details are sent over the web unencrypted, and it is very concerning that a company of this size would allow that to happen. It is coincidental that when creating a shortcut to the login page, I did so with the first link.
I have contacted Fox support directly so they can hopefully resolve this.
