Holiday Set Up
Hi everyone, I am new to Solar and this forum.
I have a 6.8Kw system and a 6KW inverter...is there any information on set up for holiday...I am trying to set up my system so that whilst I am away the battery charges via solar only to around 30% to run the house overnight and then the rest to grid...I have tried a few schedules on the app but to no avail.
Any help or assistance would be gratefully received. Thank you
Re: Holiday Set Up
A few ways to do this, perhaps most simple is to have system in 'Self-use' basic work mode.
In quick settings, put max SoC for the battery to 30%, when back just change max SoC to 100%
Re: Holiday Set Up
Thank you for info. Agree that’s very straightforward. I will use that :D
Is there additional ways that I could look at trying via the scheduler too?
Thank you
Re: Holiday Set Up
You could use advanced scheduler, have the default work mode as 'Feed-in'
Then set a schedule from 06:00 to 18:00 for 'Self-use' max SoC 30%
In theory that should work also, you don't need to have it run that long, but say 11:00 to 13:00.
Re: Holiday Set Up
Thank you for the alternatives. Will give those a try too. Thank you for the guidance. Much appreciated. :D
