Today I noticed the app showing firmware update for the inverter so I started them....and a painfully slow 30 mins later all 3 had completed
Attached screendump after update ....are these the latest and if so what has changed ?
FOX KH7 7kw hybrid inverter
EN-EPS-BOX-SP gateway
You can check what the latest versions are here viewtopic.php?t=1927
- also it tells you (for a while) in the app if you're on latest.
As for what's changed - very hard to know for certain, since FoxESS haven't issued any release notes for months.
H1 5.0 E G2 inverter
EP11 battery
3680W solar 8 panels
EP11 battery
Thank you, the ones I have are the latest
edit to your footnote......the updates can now be installed via the app
You might also now see they have lost the 'Latest' tag on the end (have same inverter and loaded firmware the other day)
Could suggest they have removed the update process again.
also noticed this.....should surely read CHARGE from PV enabled.....
Anyone know the latest firmware for a a Fox H1-11.4 - US Inverter ? I'm om Master 1.2, Slave 1.02, Manager 1.17 AFCI 1.03 which seems obsolete. I can't find an official list ( or a semi official list). If a Cdn or US user could post their latest firmware Versions that would help me with a recalcitrant Installer and Fox Support.
Ask your question here viewtopic.php?p=6624#p6624Farfarer wrote: ↑Tue Aug 11, 2026 5:57 pm Anyone know the latest firmware for a a Fox H1-11.4 - US Inverter ? I'm om Master 1.2, Slave 1.02, Manager 1.17 AFCI 1.03 which seems obsolete. I can't find an official list ( or a semi official list). If a Cdn or US user could post their latest firmware Versions that would help me with a recalcitrant Installer and Fox Support.
Seems there is one or two users with same kit, posting might send a notification of a new post.
