BMS lost error
Hi, my inverter shows ‘BMS Lost’ as an active error.
The app's showing as offline and we've had no data feed for 2 days with everything showing '0'.
The red warning light on the inverter itself is flashing red and the dongle is fast flashing red.
So far no luck with getting a solution from our installer.
I'm hoping this doesn't mean there's no PV production to the house or battery.
Any thoughts on how to resolve would be very welcome.
Phil
Our set up:
Fox ESS H1-5.0 inverter
Fox ESS ECS4800-H3 (13.98 kWh total) battery
4.25 kW PV array
8kW Air source heat pump
Re: BMS lost error
"BMS Lost" means the inverter has lost comms with the battery management system.
Very likely you will be having no power generated by the system.
Check the BMS cable between the inverter and the battery for damage and that the connectors are seated correctly.
Check the battery status indicators then try a complete restart of the system
Shut-down
  • Switch off the solar input (switch at bottom left of inverter)
    Switch off AC input to inverter (red switch near inverter)
    Switch off battery (switch off the DC breaker on the battery
Wait 30 secs
Start-up
  • Switch on PV input
    Switch on AC input
    Switch on battery DC breaker
    Press battery Power button
If you don't have the handbooks a copy for the inverter is here and the battery is here
Manager(ARM):1.76
Master:1.57
BMS:1.012
Re: BMS lost error
MANY thanks. Just tried this, but no change. None of the LED status indicators are lit up, if that's a clue?
Re: BMS lost error
Bob&I wrote: Fri Aug 07, 2026 9:03 am MANY thanks. Just tried this, but no change. None of the LED status indicators are lit up, if that's a clue?
Sounds as if the battery has powered off?, on the master make sure the DC switch on the battery is on, and then press the power button and shortly after the LED status light should come on.
Re: BMS lost error
As per Dave's reply that should start the battery.
Could you post a photo of the left hand side of the battery with the cover over the circuit breakers open.
I gave the wrong link for the battery manual, I've now corrected that (the control panel on the battery is the same though).
Manager(ARM):1.76
Master:1.57
BMS:1.012
