My system is currently set to force charge over night. I want to cancel that but the force charge setup doesn't appear to be reflected in the app or via the cloud portal.
Where should I be looking? The app shows the system as being in Self Use mode and there is nothing showing under the mode scheduler.
TIA
It is possible that your system was set to use the older charge periods that have now been removed from the app (in favour of schedules).
If you have the Energy Stats app that still allows the older charge periods to be set/unset - or alternatively if using the Fox app you create a schedule (doesn’t really matter what it is, as when saved it will clear any old charge periods), save it and then go back in later, and disable the schedule by setting the work mode to Self Use.
