Latest Firmware version for H3 Smart 15.0
Hi All, do you know where's the best place to find latest firmware versions for my inverter i.e. H3 Smart 15.0?
Re: Latest Firmware version for H3 Smart 15.0
Here is a master list, take a look and see. It might be a little out of date as Will hasn't updated for a few weeks, but close enough to compare.
viewtopic.php?p=8069#p8069
I recently installed a H3-15.0-Smart as well. To check if your firmware versions are the latest. Go to device > Select Inverter > Select your S/N under H3 Smart> this will show you the firmware versions for Master, Slave, Manager and AFCI.
Latest version
Master 1.44
Slave 1.00
Manager 1.26
AFCI 0.35
if they are not the latest, there should be a red dot next to the items to prompt you for latest update.
Hope this helps
Has anyone had any issues since upgrading? I now have an issue whereby self-use doesn't work correctly. The battery has 63% SOC however it is importing and exporting 1kw at a time rather than drawing from the battery. Before upgrading, this worked perfectly. Regretting my decision to upgrade!
