Communication Issue: Fox ESS T10-G3, DTSU666 Meter, and FoxESS EV Charger L series Integration
Hi everyone,
I’m seeking some advice regarding a communication error I’m encountering while integrating my Fox ESS T10-G3 inverter with an FoxESS EV Charger and a DTSU666 Smart Meter (direct connection).
The Setup
I have followed the wiring diagrams to connect the components via RS485 as follows:
Meter to Inverter: * DTSU666 Pin 24 (A) / 25 (B) → Inverter Pin 4 (A2) / Pin 3 (B2)
EV Charger to Inverter: * Charger A / B → Inverter Pin 1 (B1) / Pin 2 (A1)
The Problem
The connection between the Inverter and the Meter works perfectly. Data is flowing correctly, and I can see all the real-time statistics on the FoxCloud app.
However, the communication between the Inverter and the EV Charger fails. As soon as I enable "Green Mode" or Load Balancing, the FOXSwitch App displays the following error:
Error Code: MeterCommunicationAnormaly
My Goal
I want to charge my EV using 100% solar energy (Green Mode) while keeping the DTSU666 meter connected with inverter for monitoring.
Questions
Is it possible to run both the DTSU666 meter and the EV charger simultaneously on the G3 series inverter using these separate pins (A1/B1 and A2/B2)?
Does the G3 inverter support the RS485 COM 1-2 signal, or should somehow activate it?
If anyone has successfully configured a G3 inverter with an EV charger and Meter, I would greatly appreciate your insights!
Re: Communication Issue: Fox ESS T10-G3, DTSU666 Meter, and FoxESS EV Charger L series Integration
Who reads this forum, is it only those who have encountered the problem, or are there also those who know how to solve it?
Gvidonas wrote: ↑Fri Jul 03, 2026 10:53 am Who reads this forum, is it only those who have encountered the problem, or are there also those who know how to solve it?
A bit of both, but for the more obscure problems like yours, you would need somebody that had direct experience - if there is no response it's best to contact your installer or Fox support.
You need an DTSU666 with dual RS485 and connect the inverter and The EV charger to it. Then use the Foxswitch app for the EV charger.
This is the solution when using an string inverter that goes offline during night time.
Thanks for the reply.
So need to change the Smart meter to this one: DTSU666-G Three Phase 4P which has 11-12 contacts. Now installed DTSU666 which has only 24-25 pins.
Yes!
