Hi Everyone,
I noticed the FoxESS app has the Import Limit set to 9.2 kW (I tested it at 9.5 kW). When my house load increases, the inverter reduces battery charging to keep the total grid import below this limit.
My questions are:
Why was the Import Limit set to 9.2 kW?
Is this due to a FoxESS inverter limit, an electricity distributor (DNSP) requirement, or an installer setting?
My main switch is 63 A. Can the Import Limit be increased safely?
Is my house wired as whole-house backup, or are only essential/backup circuits connected through the inverter?
If the Import Limit is increased, will it affect the warranty or the approval from the electricity distributor?
