Why did this need messing with?
Today's (30 June 2026) update to the mobile app has forced the app display to mobile phone use rather than providing the user the option on which orientation the display is needed. For example, I mostly use the app on my iPad and display the app results in landscape mode, after today’s update, the Home Screen is forced into magnified portrait mode and removes the option of rotation. Not only is this very annoying but half the data is not displayed because the magnification is such that one has to scroll up to see it
I’ve also found (on my iPhone) that when I go to Quick settings and work mode scheduler it no longer shows the schedules set. You have to click on mode scheduler and the current work mode and in there the edit button is gone. You can edit and save but it now always asks you to save.
When this first happened I got errors trying to save. I had to delete all work modes and go to self use. To then be able to save. It’s all gone a bit strange.
7.2kw PV
16 x 450w JA Solar All Black
12 x SE
4 x NW
Fox H1-5.0-E-G2-WL Inverter
Ohme Pod Car Charger
12 x SE
4 x NW
Fix one thing, break another it seems.
Well hopefully it will be sorted in an update or two.
