Had a fox system installed recently with 4 batteries, it’s causing a lot of interference with my Radios when the system is charging, is there cure ??
Unfortunately the inverter ac to dc conversion is quite noisy, and depending on the frequency it can cause issues - the majority of the problems tend to be on the mains itself, with mains signalling / networking devices sometimes losing performance or connectivity.
I can’t speak for radio interference but if you have low signal strength, the s/n will be much higher than it was before so perhaps consider filters or amplifiers that improve signal to noise.
