H1-gen2-WL - Master Firmware 1.55 breaks force discharging!
Hey Comm,
I've been testing the latest firmware for the H1-gen2-WL and i've discovered that 1.55 of master breaks force discharging as the inverter just sits at idle.
Resolved by a downgrade to 1.53 again so this is more of a heads up, I've filed a bug report to Fox Engineering
Re: H1-gen2-WL - Master Firmware 1.55 breaks force discharging!
Hi Will - I’m running it too but with HA and Predbat controlling my H1-6.0-G2-WL and not seeing any force discharge issues with that control method (if it helps!)
Fox ESS H1-6.0-E-G2-WL Firmware - Master: 1.57 Slave: 1.04 Manager: 1.43 Datalogger (internal wifi) : 2.10
Fox ESS Firmware updates applied August 2026
Octopus Intelligent Go tariff
Fox replied and said they've found the issue and it will be fixed in 1.57 coming out soon.
Thanks Jim, my issue is due to some specific settings conflicting in this firmware which explains why yours is working.
JimH wrote: ↑Wed Jun 10, 2026 9:48 pm Hi Will - I’m running it too but with HA and Predbat controlling my H1-6.0-G2-WL and not seeing any force discharge issues with that control method (if it helps!)
