Dear contributors,
I just installed the FoxCloud app and I would like to know the what the "Feed-in Power" stands for.
In have no battery, just connection solar panel -> FoxESS -> grid.
Also, what is the difference between "Output power" and "Load power" in the Fox Cloud app/website?
Thank you,
Daniel
Feed-in power
Feed in, is export power - i.e. everything you export from your system to the grid.
Load power is your house load, so everything consumer within your home after the main incoming fuse/meter.
Output power is the amount of work your inverter does, if you had batteries it would be more complex but as you only have PV the output is the amount of solar being generated and output by your inverter to cover your house load and any surplus is export (or feed in).
Can you only see this in the little graphs? I can see the total yield but would like to see how much has been exported total?
If you click on the 'Statistics' tab, you can see Feed-In-Yield1 which is the total you have exported for the period selected either day, month, or yearWolfenden12 wrote: ↑Sat Aug 19, 2023 6:37 pm Can you only see this in the little graphs? I can see the total yield but would like to see how much has been exported total?
