What's in:
- Setup via Bluetooth. The Pi can provision new and existing inverters directly over BLE, so the FoxESS mobile app isn't needed for setup.
- Local telemetry every 90 s: PV power/voltage/current per string, AC power/voltage/current/frequency, inverter temperature, lifetime generation, lifetime grid export.
- Diagnostic sensors: operating state, fault state, last fault code with a human-readable message, last fault time.
- Optional cloud relay if you want the FoxESS app and cloud to keep working alongside.
- Mesh-aware: with multiple inverters, sensors expose which one is the WiFi-connected mesh root and which are followers.
- One install script sets up the AP, DHCP, redirect, daemon, and HA discovery and provision your inverter so it uses the new Wifi network.
Code, setup instructions, and a runbook:
github.com/040medien/foxess_local_gateway
