KH8 RS485 wiring help needed - connecting EW11A for Home Assistant/PredBat
I have a FoxESS KH8 hybrid inverter installed outside and I'm trying to connect it to Home Assistant using the foxess_modbus integration for real-time monitoring and PredBat battery optimisation.
My inverter has the following firmware versions:
Master: 1.6
Slave: 1.02
Manager: 1.58
I've established that the built-in FoxESS WiFi dongle has Modbus TCP locked down (Manager firmware 1.58), so I've ordered a RUANI EW11A-0 RS485 to WiFi adapter to connect via the RS485 port.
I have a few questions I'm hoping someone can help with:
1. Which pins on the KH8 are RS485 A and RS485 B? I can see from the menu structure there is a COM/RS485 connector but I need to know the exact pin numbers
2. Is there a 5V or 12V auxiliary power output on the comms connector that could power the EW11A, or will I need a separate power supply?
3. Has anyone successfully connected an EW11A to a KH8 and if so any tips or gotchas?
thanks in advance
Re: KH8 RS485 wiring help needed - connecting EW11A for Home Assistant/PredBat
broaders wrote: Tue May 19, 2026 11:49 am 1. Which pins on the KH8 are RS485 A and RS485 B? I can see from the menu structure there is a COM/RS485 connector but I need to know the exact pin numbers
thanks in advance
Check the connection types here
https://github.com/nathanmarlor/foxess_ ... ring-Guide
For reference, I have a KH7, and it uses the square shape 16-pin connection
https://github.com/nathanmarlor/foxess_ ... onnector-1
Something I personally found confusing when I wired mine up was that it was not obvious from the diagram whether the pin layout was from the top of the connector looking down, or from the underneath looking up towards the pins. What helped was comparing it to the position of the pre-existing CT clamp wires.
the pins are actually numbered inside the connector....but you need young eyes to be able to read them !! :roll:
FOX KH7 7kw hybrid inverter
EN-EPS-BOX-SP gateway
I couldn't even see the bare wires after stripping the ethernet ... it was mostly poke and hope.
Next time I would want to get some thicker RS485 comms cable rather than using ethernet.
you should stick with CAT5 UTP it is 0.5mm diameter
as per the previously linked Github thread these are the connections so you would be looking at pins 3 & 4
Hi All, I am in the same position trying to connect EW11A to a KH inverter and part of the original question was:
"Is there a 5V or 12V auxiliary power output on the comms connector that could power the EW11A, or will I need a separate power supply?"
With my KH9 inverter I have the 16 pin connector but it is not clear from pin descriptions whether there is the requested power supply pins; if so which pins and if there is no power there where is the best place to get power for the EW11A from?
(Ideally from the inverter somewhere rather than separate power supply)
