Hi there.
I recently added solar and batteries to my house. And have really enjoyed being quite self sufficient and sticking it to energy companies. I would like to take it a bit further, with the onset of winter, and have thought about getting a small wind generator.
I do mean relatively small, maybe just to top up batteries a little overnight.
Would it be possible to utilise the same system/inverter to do this? Or am I just trying to be too clever (cheapskate).
This is a tough subject as getting a wind generator installed that generates sufficient power takes a large rotor and it needs to be mounted high (10 metres),
have a look at https://www.rensmart.com/Maps it shows your wind speeds at the various heights for where you live.
The two things needed for wind power, size of blades (even the vertical fans don't increase the area of the blades significantly ) and most importantly wind speed with a clear un-interrupted outlook, and typically mounted at 10M or above e.g. a typical 2 metre micro wind turbine will produce 80-100W in 10-12mph winds.
It's written for the US market but some good information in this guide https://www.solacity.com/small-wind-turbine-truth/
If this works for you, it can be monitored by a second CT clamp from your inverter to the output of the wind generator so that the Fox inverter knows how much external generation there is, and it will use it to charge the batteries if generating enough power.
Cool, thanks for this. I think that looking into it a bit further, the wind generation needs to be a bit more positive/productive for the outlay. I think ill have to wait for more efficient turbines to make it worthwhile. It is good to know that the inverter will be able to handle it, though if/when wind generators improve.
I’m interested in this topic too, and would still be interested in how it might work.
Can you give any details as to how one would set this up?
My system is with a Fox H1 Hybrid 3.7kW inverter and a Fox ESS EP12 Plus battery.
It's more to do with the available wind power. In an urban setting, there just isn't enough wind to meaningfully power a small turbine, particularly if it is close to roof height.
Where it does work is on farms etc, if you can have a 10m+ tall mast with a fan with a blade diameter over about 1.5m in the middle of a field, away from any trees and buildings.
I live on a hill in a rural area where I get an annual average wind speed of at least 8m/s. I think this would be a worthwhile addition in my situation at least.
But how can this be integrated? Can the cables simply be plugged into the spare ports of the inverter, with the power then treated much the same as with the power generated from the PV?
