Hey guys, I was wondering what temperature is considered normal for a inverter while it is generating power? Mine is P3-Pro-15.0 and it's around 60C hitting 70C sometimes.
Thanks!
I think it will downrate around 50c?
I put a 2x140mm USB computer fan on the top of my KH inverter, and it really helps keeping the temperatures down. I haven't seen it go above about 38c since I did that last year. Although obviously that would be affected by ambient temperatures.
I think the recommended max temperature is 60c, and ideally less than that.
Does it ever get hit by direct sunlight? If so, try some sort of canopy to keep the sun off it.
If you have a power available, then maybe try the fans. These were the ones I got (USB powered).
