Hi there. Can anyone help me? I found instructions on setting up via the app to use battery power only between 4pm and midnight. But when set up even if I turn on the oven during this time our smart meter is showing grid power being used. Can anyone recommend settings so house only uses battery power during these times.
It would help if you can post the settings that you have for your schedule at this time, and a graph for the power being used. Also what inverter/battery you are using.
In 'Self-use' or 'Feed-in' work modes (typical ones used) the grid use should be minimal.
How big an oven are we talking with a kW draw? What else are you using?
How big is your inverter?
