I have a recently installed a Fox ESS KH10 single-phase hybrid inverter with around 42kWh battery in an AC-coupled setup. The existing solar system is connected to a Sungrow AC inverter.
I’m having issues with battery charging/discharging behaviour and wanted to see if anyone has experienced something similar or has ideas on what could be wrong.
Expected behaviour should be:
- Battery charges when there is excess solar generation
Battery discharges when house load is higher than solar generation
The battery continues discharging even when there is excess solar available
Battery discharges down to 10% SOC and then stops
The only way I can get the battery to charge is by increasing the minimum SOC to something like 50%
When I do that, the battery may be charging using both solar and grid power, instead of only using excess solar energy
System setup:
- Fox KH10 hybrid inverter
Approx. 42kWh battery
Existing AC Sungrow 8KW inverter + 10KW Jinko Panels
Two CT clamps installed
Distance between inverter and meter box is around 10–12 metres
- One CT is clamped on the AC cable coming from the Sungrow inverter, with the arrow pointing toward the meter box
The second CT is clamped on the grid live wire, with the arrow pointing toward the grid
Has anyone experienced similar behaviour in an AC-coupled Fox setup?
Unfortunately, the installer has been extremely busy through April and I’ve been waiting several weeks for a follow-up visit. He is finally coming back next week to “take a look,” but I wanted to check with the community first in case there are common issues in AC coupled setup.
Any advice would be greatly appreciated.
