Battery saying offline also BMS Alarm Code-234 and Code 14 how do I fix these alarms
Re: Battery saying offline also BMS Alarm Code-234 and Code 14 how do I fix these alarms
You should power down the system fully, so the inverter screen goes blank (hopefully installers left instructions)
When you start up the system, make sure that the battery pack is powered on first, and inverter is next.
