EV Charger A series, C series L series which one is the latest?
Hi All,
Does anyone know which series EV charger is the latest/best?
I have a Fox ESS Battery and now need a charger and would like it in the same app (FoxCloud 2.0) so looking at Fox chargers.
Also does anyone have a list of Australian sellers as I can only find like 2 in the whole country.
Thanks in the bank!! :D
P.S we have had our Fox battery for almost 2 month as we are supper happy with it.
It never goes below 75% and the power company is always in the red. Bills < zero.
Re: EV Charger A series, C series L series which one is the latest?
Hey Josh, any update on this?
I've got the kh10 inverter and I'm thinking the a series is the go to, but I'm having trouble finding how it can connect.
Hi Mike,
I was told by a supplier here the 'L' Series is the newer one.
Beside the detachable cable option it has everything the 'A' series has.
One thing the 'L' has is the cables going to the power box can go straight into the back which the A can't
Nobody got back to me on here but maybe this will start a thread on it.
I've attached the data sheet for the 'L' and the 'A'
As for the inverter Mike, the chargers don't have any connection with them, it's own circuit it the switch board.
The way they interact is via the FoxCloud2.0 APP so you can set different triggers for stuff.
Anyway hope that helps
FoxESS A7300P1 Datasheet.pdf
(604.62 KiB) Downloaded 171 times
FoxESS L011 Datasheet.pdf
(557.45 KiB) Downloaded 164 times
Thanks for that Josh.
Yeah it's a shame the info is so hard to come by.
I'm looking at an A series, but I'm slightly concerned that if the only comms is via the app and cloud, then it will react really slowly to PV linkage and changes in PV output etc.
Another thread I've got going says comms can go to the inverter. I'll try and find more info.
Hi Josh et al - Following your progress with great interest because I also have a Fox battery (41.93kWh) & inverter (15kW)
There is also the C series EV charger which I understand has TWO EV charging ports - perfect for a 2 EV car household.
Hi Mike,
I could be wrong here but I think the PV stuff gets triggered directly from the meter (over rs485)
Is that what you mean, when there is extra solar being produced put it in the car?
I think the app is just for changing setting and displaying data.
Good point though if it has to wait for the app to update with its current situation then trigger a reaction.
Let me know what you find, id be very interested if there is a bottle neck I should be addressing.
Hi Gino, Yeah super happy with the big battery hey, mine hasn't been below 78% yet :D . Ok so that's what the C series is a duel charger, definitely would be the go if you had two car spots. I can't find any info on it here in Aust
My install is booked for two weeks away L series, I will let you guys know how it goes (Hopefully the car will arrive at the same time :roll: )
awesome - how exciting a charger AND an EV :D Super keen to hear how it pans out. Yeh I've been cycling my 42kWh battery every day and achieving monthly credits through Flow Power
Hey Josh,
Yeah maybe if it gets triggered from the meter that'd be good! Just haven't seen that anywhere.
I guess i'll have to guinea pig it...
Let us know how the L series install goes. I'll be going the A series and installing a meter too. Fun and games.
Spoke to fox on the phone. They said the A seriec charger doesn't need to go though a smart meter.
Ev charger connects to ports 3 and 4 on the Kh inverter. A-A and B-B.
Will see how we go!
What you managed to get someone from Fox on the phone, it's a miracle!
That's cool, so to the inverter.
Did they happen to mention anything if you do have a smart meter?
I'm in the opposite boat to you, my smart meter is close to where the charger is getting installed and my kh inverter is on the other side of the house so running an extra cable will be a pain.
Have you got a date planned for your install?
Thanks mate
Hey Josh,
Sorry for the slow replies mate.
Yeah haha they answered straight away!! Was impressed.
If you have a smart meter, then I believe the wiring from the charger goes straight to the smart meter, and it handles both. There is a diagram in one of the pdfs that shows that.
Here is the link to the downloads that came in the a series box.
https://charging.foxesscloud.com/doc/#/ ... bbe536bf2b
I've got it on the wall and am running cables this week, so hopefully will have it working in a week or so!
In your case, did they run a cat6 cable? There may be spare wires running from your power box to your inverter that aren't being used, as the smart meter is probably only using 2.
Glad I found this thread.
Ordered a single-phase A series charger for my upcoming EV. The documents posted have really helped and just have a couple of questions. Have a KH9.9 FoxESS inverter currently DC coupled with 6.6kw Solar & 23.3kw battery so am looking to take advantage of charging using excess solar etc.
1. Our place has a side-by-side carport & garage. The smart meter is in the carport and planning to install the EV charger on the inside of the garage. Will be on the other side of the wall to where the meter is. The garage and carport are separate to the house itself. Our KH9.9 inverter & existing switchboard is 20m away so it's practically impossible to run a cable neatly between the Inverter & EV Charger. Can the EV charger communicate with the Inverter through WiFi to take excess solar? Or can this be done via the Smart Meter with no direct connection to the inverter?
2. Have noticed on the installation instructions that it needs to be set up initially with the Foxswitch app needing an installer account. Our sparkie that we use won't have an installer account. I've ordered the charger through Revcharge. Will they provide an installer account to use, or should I attempt to set up one myself?
hey guys, from melb here.
I have A series to KH10 and EQ4800L9. SIngle phase dc coupled.
My understanding is A series is newer than L series. A series lets you use swipe card to charge etc (I don't use this feature at home).
The green charge is always the hottest topic on Fox EV charger. I had a long journey to get green charge working, I was lucky enough to get some help directly from FoxESS Australia support and they came onsite to my place to investigate and fix.
For green charge to work, you will need rs485 from EV charger to the inverter - this is a must. This connections allows the ev charger to communicate with the inverter directly to assess the excess solar.
I haven't been able to really test this yet as it's winter here and I'm with globird zero hero plan (free 11am-2pm) and by the time zero hero ends, the sun is already pretty much on the low side.
Hey wonderful feedback cpurn. As they days lengthen and green charge begins to kick in more often keep an eye out for the following
" The Fox ESS A-Series EV Charger requires a minimum of 6 amps to initiate and sustain charging.This means the charger needs roughly 1.4 kW of power (for single-phase setups) . If the charging current or the available excess solar dips below 6 amps, the charger will automatically pause."
Also, your charger may well be "V2G hardware ready". Can't wait for Fox ESS to activate the associated software.
Hope to hear from you
Kind Regards
