I haven't logged into the Fox ESS cloud app or website for a few months, but I did so today to try to disable Charge from Grid now that we're getting regularly sunny weather.
The problem is, I can no longer find the charge from grid settings in the app or on the website. I can still find System Min. SOC and System Max. SoC settings, but nothing for configuring the schedule or enabling/disabling the charging.
Can anyone advise how I can disable this?
Fox ESS H1-6.0-E-G2 inverter
Fox ESS EP11 battery
JA Solar 420W PV panels x14 (5.88kW)
Two choices I can think of, since they removed this from the website.
1. go to the Inverter and carefully navigate the menus to disable the charge session (hopefully it appears there?)
2. load Energy Stats by AI Priest from App store on phone/table and see if you can view the schedule
I found the settings in the Inverter front panel menu: Settings -> Work Mode -> Charge time and was able to disable it there.
Mind-boggling decision from Fox ESS to remove that setting from the app and cloud website though.
Thank you for posting the exact details on where to find it, knew it was lurking somewhere in a menu
