Control Mode Scheduler from Home Assistant
I have been using Axle, so far so good in terms of events and payment but I find I have to fiddle about with Mode Scheduler after each event. Prior to Axle, I didn’t have any truck with MS but Axle don’t seem able to restore my normal settings. So, can I use HA to make the changes automatically. I have installed the Axle / HA stuff.
Zappi V2 charger and 2 EVs.
Re: Control Mode Scheduler from Home Assistant
I think Wyndstryke might be able to help if he finds the post, uses HA and has been an Axle member for a while.
