I have 22 455w JA Deepblue 4.0 pro panels. I use 10'000kwh per year.
I am a bit googly eyed from researching this but if i buy a Fox KH9 inverter combined with an Fox ess ep12 battery are they compatible and a good match or is there a better solution?
Inverter and battery are fine with each other.
As for panels are they in a single string of 22 panels, or split?
Then someone can make sure they are fine (start-up Voltages/max etc)
The panels would be split into 3 or 4 strings of even numbers as i get low winter sun early morning tree shading at each end.
