Toggling the forced charge period.
About a month ago I set the batteries to charge from grid between 3am and 5am. I now want to switch this off as Solar is producing enough for me. However, it seems the app has changed and I can not find the toggle anymore. I have read many of the forums with similar topic and have learnt how to schedule a "forced charge". However, this does not tell me how to switch the old schedule (pre new App) to switch off! Anyone out there who has solved this? Many thanks
Re: Toggling the forced charge period.
You'll need to use the desktop version to disable this old charging slots and use mode scheduler going forward.
Thanks for the prompt reply Will.
So I am using desktop and it seems the same as the app. There was no scheduled battery charging to see. I am very conscious that I may be in the wrong area (I had to go to the "new version available button" to even see any battery setting info by the way). Im doing something wrong, can you give me more help please?
Im very grateful for your time.
Sorry, one image shows that I have newly added a scheduled battery charge just to see if by toggling on and off it will override the original timed charge.
"Grid Charging Time" at the top of the quick settings is where you find the basic timed charge.
Thanks MaterialBarracuda. Before I read your message, I restarted my system. Perhaps this is why I see this in charging now.
That looks like it should work now, have to post back if it isn't working as intended.
Yes, it didn't charge let night so Im now sorted. Thanks all. Jem
Perfect, hope it carries on the same.
But now I can set it to charge from the desktop . Any ideas? Error 44098
I have checked that mode scheduler is switched off (as on another forum it says that could be an issue). Thnaks
I see this in scheduler (which I can not remove)
Don't know why but its now accepted and times have been submitted, with the app working before so well I cant understand why this has been made so hard by "improving" the app. Thanks for all who have helped.
