Force Charging With 'Charge from Grid' Disabled on AC1 5.0 Inverter Used to Work in App but No More, have to use Desktop
Hi all
This time of year with sunnier days I would normally set my Batterys to Force Charge during the cheap energy period BUT with the 'Charge From Grid' toggle Disabled.
This means the batterys dont discharge into my car when it is charging but also dont Charge from the grid as the sun is charging the batterys in the day.
This year after an app update this toggle for Charge from Grid is still present but doesnt stop the batterys from charging from the grid. The toggle can be set to enable or disable and it still charges from the grid.
I have spoken to Foxess Support and they said they are aware of this and are planning for it to be fixed, possibly in April.
Does anyone have a work around that does not require rewiring the system?
For example would setting the SOC to 90% during the hours of EV charging achieve the same goal.
Thanks in advance.
Re: Charge From Grid - Toggle within Force Charge Mode
Your image is missing, if you can add it to your post.
Have added screenshot with Charge from Grid toggle circled.
Don't you just touch on it to enable it?
It doesn't matter if its enabled or disabled it still charges from the grid.
Can you expand on your tariff information?
I presume you charge the car on a cheap overnight rate, and you would normally charge up the house battery at the same time? Do you then change this behaviour when it gets sunnier so that you charge up your battery from the solar?
Do you have export payments? If yes, then can you tell us your price for cheap night rate and your export price please.
If your night rate is lower than your export rate in the day, it would be better to charge the battery in full, and export solar at the higher payment amount.
The other choice is to wait for the next few months to await Firmware updates from Fox.
After much back and forth with Foxess Helpdesk, Alex persevered and did a great job, there is a way around this issue.
Firstly disable the Work Scheduler in the app - Go to the app - Click on Work Mode - Click on Blue Opposing Arrows in top right corner - select Self Use. This turns off Work Scheduler in the app and prevents the 44096 error when setting the Forced Charge in the Desktop website.
- Using Version 1 Desktop foxesscloud.com go into your Inverter Details screen
- Click on the Red Bubbles to the right of Battery Status
Screenshot from 2026-05-06 09-51-09.png (19.25 KiB) Viewed 42987 times
- A window will open to set your times for a Forced Charge
- Set your times
- Enable or disable charge from Grid
- Save
These settings will not appear in your app
If you get a 44096 error its because your Work Scheduler in the app is still enabled or basically not set to Self Use
This is far from ideal and who knows when V1 of the website will be pulled but works for now I guess.
Re: Force Charging With 'Charge from Grid' Disabled on AC1 5.0 Inverter Used to Work in App but No More, have to use Des
The latest version of the app now allows the Max SOC to be set to limit the charge from the grid and solar during a Forced Charge.
Settling the Max SOC works.
Presume that a toggle for enabling or disabling Charge From Grid is on its way as it mentions this functionality in the Forced Charge screen.
After using the Version 1 Foxess Cloud method of setting Forced Charge without Charge from Grid I have realised that those settings dont appear to be retained.
The settings seem to be reset at some point in the day, maybe midday.
So if needed for consecutive days the settings need to be set daily.
