Is there a way we could create a page to track the latest/current versions of firmware for each inverter, BMS, etc.
I find it quite odd that this isn't listed on the FoxESS site with a description of change notes between versions.
Many thanks,
Stu
FoxESS H1 6kW Hybrid Inverter
Fox Energy Cube 4.03kWh HV Battery (Master) (Coming November 22)
Fox Energy Cube 4.03kWh HV Battery (Slave) x4 (Coming November 22)
Total 20.15kwh storage
19 x 410w Array
19 x 410w Array
I have a topic here viewforum.php?f=29
Annoyingly the firmware numbers are different for each inverter type so a H1 has a different firmware to an AIO for example making the numbering really hard to manage.
Yeah I saw that page. I guess I was meaning a hardware list that then gave you the current versions and upgrade notes (if there are any)
Like hybrids:
Master version = xxx
Slave version = xxx
Manager version = xxx
Etc, etc.
I had a call with FoxESS recently and they upgraded my firmware. However, not to the newest versions. It was only when I was reading on the Facebook group I realised. So made another call and got the latest versions.
I guess it's a lot of work and to be honest only stat geeks like myself would look at it. Thanks anyway and keep up the great work.
Like hybrids:
Slave version = xxx
Etc, etc.
19 x 410w Array
19 x 410w Array
Foxess don't publish change logs but we'll use the topic quoted above to try to expose changes and versions as we see them.
I keep a log of firmware and any noteworthy changes here viewtopic.php?t=1927
