High Readings on Revenue Calander
HI
I have noticed some strange very high readings on the Revenue Calendar View, i attach a picture of the issue where you can see on the 1,2,3,4,5,6,7,&8 of Feb the readings were very high. These figures do not show up with Octopus and for sure we never used that much power to show these negative figures. Can someone advise how to re-set these numbers, maybe a de install and re install of the app but i wanted to check first if there is another way.
Thankyou
Carl.
Re: High Readings on Revenue Calander
Usually caused by an error in the tariff price entry at some point.
AFAIK there is no way to reset the values, happy to be corrected.
I don't track this way, only by a trusted spreadsheet, my app shows £0.00 after a year.
Thankyou
I wish there was a better answer for you, maybe someone knows a trick?
If you are not bad with spreadsheets, this is a good way to track with more accurate values.
