Force charging settings
Hi all.
I can't seem to find the section on the app where I can see and also edit my force charging times .
I'm sure this was under battery settings but can't find it now.
Did something change when the app got its face lift ?
Josh
33 panels split into two phases
2 x Inverter Fox H1-6.0-E-G2
2 x Battery Fox EP5
Running home on one phase and glamping business on the other .
EPS enabled .
Re: Force charging settings
Will has a video, it was moved about.
Alternatively, login with your credentials here
Go to the Quick Settings top right, and you can find the basic battery charge function there
Thanks for the reply but when I go into work mode card there is no info or button for Forced charge as shown in the attached yt video . Infact there is no Forced charge or Forced discharge button on my app. Any ideas ?
In the meantime I have found the info needed on the desktop version thank you..
2 x Battery Fox EP5
EPS enabled .
It was pulled from the App a few versions back, now the website is the way for the basic charging.
Best of luck with it again.
Oh right. That will explain why I can't find it. Thanks for your help.
Josh
2 x Battery Fox EP5
EPS enabled .
Mhys1016 wrote: ↑Mon Mar 16, 2026 12:17 pm Oh right. That will explain why I can't find it. Thanks for your help.
Josh
A pleasure Josh
