API with Powershell
Could someone help me out?
$deviceSN = "60KBxxxxxxx"
$token = "xxxxx-6b84-4b8b-xxxx-xxxxxxxx"
$timestamp = [DateTimeOffset]::UtcNow.ToUnixTimeMilliseconds()
$path = "/op/v1/device/real/query"
$dataToSign = "$path`r`n$token`r`n$timestamp"
$signature = [BitConverter]::ToString([System.Security.Cryptography.MD5]::Create().ComputeHash([System.Text.Encoding]::UTF8.GetBytes($dataToSign))).Replace("-", "").ToLower()
$headers = @{
    'Token' = $token
    'Lang' = 'en'
    'Timezone' = 'Australia/Sydney'
    'Timestamp' = $timestamp
    'Content-Type' = 'application/json'
    'Signature' = $signature
$body = @{
    deviceSN = $deviceSN
} | ConvertTo-Json -Compress
try {
    $response = Invoke-RestMethod -Uri "https://www.foxesscloud.com/op/v0/device/real/query" -Method Post -Headers $headers -Body $body -ContentType "application/json"
    Write-Output "$($response | ConvertTo-Json)"
} catch {
    Write-Output "$($_.Exception.Message)"
    if ($_.Exception.Response) {
        $responseStream = $_.Exception.Response.GetResponseStream()
        $reader = New-Object System.IO.StreamReader($responseStream)
        $responseText = $reader.ReadToEnd()
        Write-Output "$responseText"
    } else {
        Write-Output ""
and this is what I receive,
"errno": 40256,
"msg": "Please close and reopen this page illegal signature"
Any idea? Thanks
Re: API with Powershell
\\r\\n in the signature is a literal. Its not CR LF.
H1-6.0-E hybrid inverter
6 x HV2600 v2 batteries
16 x JA Solar 405w panels
7 x Tigo TS4-A-O optimisers
I have updated to
$dataToSign = "$path\r\n$token\r\n$timestamp"
and result of the variable is
/op/v1/device/real/query\r\n4364a14f-6b84-4b8b-aee8-7002970fd5b2\r\n1773432718686
but the script still returns the same error
Still not right by the look of it. \\ not \
$dataToSign = "$path\\r\\n$token\\r\\n$timestamp"
/op/v1/device/real/query\\r\\n4364a14f-6b84-4b8b-aee8-7002970fd5b2\\r\\n1773448842692
Same error.
Here's an example of a signature that I just tested and works for your data:
getting real-time data
body = {"sns": ["60KB10305BLB028"]}
path = /op/v1/device/real/query
headers = {'Token': '4364a14f-6b84-4b8b-aee8-7002970fd5b2', 'Lang': 'en', 'User-Agent': 'Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36', 'Timezone': 'Australia/Sydney', 'Timestamp': '1773509198752', 'Content-Type': 'application/json', 'Signature': '73d98dfa6f4a80d075078eadc9e9ae17'}
Copy the parameters from this and check you are generating the correct signature.
Once this is working, you may want to generate a new API key as anyone could copy and use the key you published here.
