The datalogger does not come online.
Hello, I'm having trouble connecting my data logger to the Wi-Fi network. My data logger is an M4. It shows as connected on my router, and the lights on the logger are also correct – solid red and flashing green. The app asks me to wait 3 to 5 minutes, but it doesn't go beyond that. I've already changed the network name to avoid special characters, and the password is also the same. I believe the network connection is fine, but it could be a problem like an update issue or a problem with the device itself.
Re: The datalogger does not come online.
Is this a new installation?
yes
In your second picture, does it say when translated: 'End User' as you user account type?
As you may need to have Installer account to setup your plant details? (I would add I am not 100% if this is correct)
Regarding that, it's just a detail, since the installer account didn't solve it either. Perhaps there's an update to be done? Or maybe some function is disabled in the datalogger.
Has the WLAN device appeared in the Devices section on the site?
yes
Macedo wrote: ↑Thu Mar 12, 2026 5:27 pmyes
Is it just that device?
And if you try to add new device, Inverter via serial number, does it work or timeout?
