Editing SOC values
Im trying to change the system and back up. SOC values but constantly get unable to write
Re: Editing SOC values
Many thanks I’d guessed that but didn’t want to delete and re type schedules, no pain no gain
Westysprinter wrote: ↑Thu Mar 12, 2026 11:38 am Many thanks I’d guessed that but didn’t want to delete and re type schedules, no pain no gain
There's no point bothering with the global settings if you want to use schedules as they seem to be ignored then, just edit the min/max SoC in them.
Deleted the schedule and it hasn’t worked I still can’t write values
Westysprinter wrote: ↑Thu Mar 12, 2026 11:43 am Deleted the schedule and it hasn’t worked I still can’t write values
Did you also change the work mode?
Yes
Westysprinter wrote: ↑Thu Mar 12, 2026 4:06 pmYes
Then other changes on Fox servers must have happened.
Have you been using the FoxCloud2.0 App all this time?
Did you try alternatives?
https://www.foxesscloud.com/login
Energy Stats by AI Priest (find in App Store) viewtopic.php?p=2680#p2680
Did you get an error code, or just a naff message when writing values?
Message says “unable to write”
The alternative access points didn't work either?
